11
Discussion topic: Sky tv not working
This message was authored by Daniel+tom This message was authored by: Daniel+tom
Sky tv not working
My sky q box won't let me watch netflix, live TV, recorded stuff or YouTube. It just comes up with a black screen and no sound, there are no messages on screen and it says everything is connected and working fine in the settings menu? Can anyone help
This message was authored by oldfella This message was authored by: oldfella Answer
Re: Sky tv not working
Hi @Daniel+tom
First make sure that the TV is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
Hi @Daniel+tom
Press
Home 1 0 8 0 Home
Daniel+tom
Thank you for your help, all working now
This message was authored by Malcolm2024 This message was authored by: Malcolm2024
Yvonne not working. Black screen. Bug volume's ok. No lights on a box
This message was authored by Invisiblename This message was authored by: Invisiblename
Is Yvonne poorly or just out of a job??
I am just another Sky customer!
This message was authored by Jesspoke This message was authored by: Jesspoke
My tv has not work for months
What did Sky say when you reported that to them?
This message was authored by Daniel0210 This message was authored by: Daniel0210
@Jesspoke
Your TV or your Sky Q box? In what way isn't the Sky box working? Unless you've told Sky there's a problem with the Sky Q box they won't be able to help you.
▪️I AM NOT A SKY EMPLOYEE ▪️
This message was authored by 1988 This message was authored by: 1988
No signal
@1988 wrote:
No signal
@1988
Not a lot to go on there but if a message is displaying ”No signal” it tends to be from your TV (in which case check the HDMI cable between the Sky Q box and your TV).
Any “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
It’s not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
Is written on the screen that you need a satellite signal
@1988
Then the second part of my post applies.
