Discussion topic: Relocate ariel/dish
This message was authored by: Sarah182305
Relocate ariel/dish
Ive had to move my house around and move the lounge to another room, can. I get the ariel wire moved around to that sode of the house from where it currently is?
Re: Relocate ariel/dish
@Sarah182305
If it's possible Sky will charge about £65 for this. If you go with a local independent satellite company get a quote first.
This message was authored by: Christinediesel
Need ariel moved from one side of the room to the other side
@Christinediesel
Sky have no responsibility for moving 'aerial' wiring and will only move Sky box wiring between the box and your satellite dish as per my earlier reply.
@Christinediesel  Do you really mean Satellite dish cable or aerial cable?
Both can be extended by purchasing extension kits from many electrical retailers.
As per @Daniel0210  Sky won't do anything with an Aerial as that is not their responsibility.
This message was authored by: Invisiblename
As you won the dish & associated cables, probably be quicker to get a local company in - it'll cost you either way.
I am just another Sky customer!
