Discussion topic: Sky tv and apps
This message was authored by: Marzena07
Sky tv and apps
My sky tv and apps don't work for the past days....
Anyone else has the same issue?
if so , what is the reason for this problem????
Re: Sky tv and apps
@Marzena07
What TV service do you have:
Sky Q, Glass or Stream ?
This message was authored by: RebeccaGilmore
Re: Sky tv and apps
Mine is the same won't load either
This message was authored by: J3nnie
Re: Sky tv and apps
Yes I'm the same have to keep restarting the stream box
it's so annoying
Re: Sky tv and apps
it's so annoying
Make sure you are actually exiting the apps and not just pressing the home button when you are finished with them. Some apps have exit options in their menus, or go to the apps Home Screen and press the back button until the app exits and it takes you to the Sky streaming Home Screen.
Re: Sky tv and apps
Try a reboot of your broadband router and do a refresh of your apps.
  1. Press Home on your Sky remote, then select Settings
  2. Press System management then Resets and updates and finally Refresh apps.
  3. You'll see a message that says, 'Your apps are being refreshed'.
  4. Press Dismiss to return to normal viewing.
The apps refresh can take 24 hours to complete.
More info in this Sky help article;
https://www.sky.com/help/home/sky-tv/sky-tv-stream/fixing-a-problem-sky-stream/fixing-sky-glass-tv-a...
Avatar for Marzena07
Re: Sky tv and apps
Hi there,
I did it, the apps are back but tv channels are gone. Therre is a message on my tv satellite issue?
Re: Sky tv and apps
@Marzena07
If you have Sky Q, as you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Re: Sky tv and apps
it's so annoying
This is the Q forum, not Stream so probably unrelated issues.
Re: Sky tv and apps
Satellite signal issue, presumably, which relates to an individual dish, LNB or cabling (or their equivalent in a communal system)
A satellite issue would affect many millions of households, and then this forum would explode.
