Discussion topic: Sky q remote
Message posted on 26 Apr 2025 04:35 PM
Sky q remote
Message posted on 26 Apr 2025 04:45 PM
Re: Sky q remote
@PCS wrote:
Old remote stopped working even with new batteries. Nothing worked at all. Ordered and received new remote but still doesn't work.
Hi @PCS
First reboot your Q box.
Then, with the Q box on with green led try completly resetting your Bluetooth remote.
