Discussion topic: Sky set up
Message posted on 04 Jan 2025 12:48 PM
Sky set up
I have received a new sky card as the other was not connecting with the new box. The set up won't install and I have a on screen message of no satellite signal
Message posted on 04 Jan 2025 01:00 PM
Re: Sky set up
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Message posted on 04 Jan 2025 01:12 PM
Re: Sky set up
@Jasmeena wrote:I have received a new sky card as the other was not connecting with the new box. The set up won't install and I have a on screen message of no satellite signal
Tell us more about the new box. If this is a replacement Sky+HD Box that you've acquired from somewhere, I'm afraid it won't work as it's no longer possible to pair a card to it.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 04 Jan 2025 11:32 PM
Re: Sky set up
It was a replacement box issued by sky due to having no satellite signal. The box arrived in the post, no engineer was offered. Box still didn't work and sky told me they had to issue a replacement card. The card has arrived and still won't work.
Message posted on 05 Jan 2025 12:29 AM
Re: Sky set up
@Jasmeena That would be a Sky Q box not a Sky+ box where you originally posted this.
Therefore I've moved your post to the Sky Q forum.
Message posted on 05 Jan 2025 06:40 AM
Re: Sky set up
hi @Jasmeena
do you have your own dish or is it connected to a communal system ?
If the latter then it is likely you need to change the LNB type
This only applies if you are connected to a communal system
You will need to check/change the LNB type to SCR - this is in an engineer's menu
To access it :
press Home
Scroll to Settings - but do not press enter/select at this point
Press 0 0 1 in sequence followed by the Enter/ select button
you should now get the engineer's menu
Select the LNB Type & set to SCR if necessary
After changing the LNB type power down your SKY Q box and restart it for the change to come into effect
Message posted on 05 Jan 2025 10:50 AM
Re: Sky set up
Still no change. Nothing wrong with the communal service either.
Message posted on 05 Jan 2025 10:54 AM - last edited: 05 Jan 2025 10:55 AM
Re: Sky set up
Message posted on 05 Jan 2025 12:32 PM
Re: Sky set up
@Jasmeena You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
