3
This discussion topic has been answered Discussion topic: Getting my Sky Q remote to turn my tv off
This message was authored by: Mataius
My Samsung Tv model: QE65QN90DATXXU isn't listed on the handset list. Unsung the closest from the list I can adjust the volume etc, but not turn the tv off with the sky remote?
This message was authored by: PandJ2020 Answer
Re: Getting my Sky Q remote to turn my tv off
Ensure you're holding the power button for a few seconds.
Hi @Mataius
Just select the Samsung Brand.
Then instead of using the Model designation select Find it for me.
This will then give you all the Samsung options to try
A manufacturer using different IR codes between models for something as basic as power off seems ridiculous. Panasonic have used the same codes since forever.
