8
This discussion topic has been answered Discussion topic: Sky remote not working
This message was authored by: PL1980
My sky remote has suddenly stopped working. I have put in brand new batteries but still not working. Can't even turn the box on with it. Why should I do?
This message was authored by: Skull+Treaty Answer
Re: Sky remote not working
@PL1980
I had started to get something similar also, every few months or so the box will fail to turn on; using the remote or the button on the box itself - it simply remains unresponsive.
The remote is fine as it turns the TV on & off etc. just no response at all from the Q box.
In order for me to get it to work, I've had to remove the power to the Q box for 30 seconds or so then plug it back in/restore the power. After that, no issues (for a few months)
"Sometimes, the only choices you have are bad ones, but you still have to choose"
Avatar for PL1980
Actually, it seems to be the box. It won't turn on at all. It's currently on stand by
@PL1980
Avatar for PL1980
Many thanks. This worked. Hope I remember fair the next time haha
This message was authored by: Ihatesky1
Oh sweet god. I hate sky. I can't even cancel the bloody thing because I CANT GET THROUGH TO ANYONE!!!!!!!!!
my remote doesn't work.
@Ihatesky1 Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
That's great thanks. I still can't get through to sky. I'd like to upgrade the sky box I have etc. is there anyway to do this online? Thanks.
Hi,
I tried resetting the remote, but I can't even get the led flashing?
This message was authored by: AustraliaJon81
Hi guys,
remote still not working after switching box off and trying the 7/9 and 1/3 to get it to be the sole remote..?
any ideas what might be going wrong..?
Answered - Go to Answer
