Discussion topic: Sky Q box is struggling to record.also slow at changing channels.i have deleted all from recordings
This message was authored by: Allan26
Im having to switch off box if I change channels frequently.
system seems to slowing right down
Re: Sky Q box is struggling to record.also slow at changing channels.i have deleted all from recordi
Hi @Allan26
After the Reset you will have to re pair your Bluetooth remote .
Avatar for Allan26
Thanks oldfella,
I have done this.
still taking a long time to change channels.
allan
@Allan26 wrote:
Thanks oldfella,
I have done this.
allan
See how it goes @Allan26 .
If the issues continues best to contact Sky for an Engineer
