Discussion topic: Sky remote code for EMtronics TV
Message posted on 18 May 2023 07:12 PM
Please can you advise when the remote control codes will be available for my new EMtronics TV? I am fed up with having to use 2 remotes, and not being able to use the voice control 😞
Message posted on 18 May 2023 08:10 PM
Re: Sky remote code for EMtronics TV
@Ronnie21 have you tried the using the codes for the vestel brand as they make a lot of TV's under different names
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 18 May 2023 08:17 PM
Message posted on 18 May 2023 08:30 PM
thanks, that worked!!!
Message posted on 18 May 2023 09:26 PM
@Ronnie21 what one worked the vestel or the other brands ?
Message posted on 22 Jul 2023 11:42 AM
Just in a job now and JVC codes worked.
Message posted on 30 Sep 2023 01:48 PM
What code worked having same issue ??
Message posted on 15 Dec 2023 11:53 PM
Does anyone know where I can find the codes for the Emtronic EM32HDRW?
I've tried all the Emtronics models and the other brands codes.
many thanks
Message posted on 16 Dec 2023 09:13 AM
many thanks
@Jackowock have you tried the Vestel codes
Message posted on 16 Dec 2023 09:16 AM
Yes I have, but thanks for the suggestion.
Message posted on 06 Jan 2024 02:20 PM
Hi, just purchased and set up a Emtronics EM40ROK TV with my Sky Mini Hub.
Tried to pair my Sky Q remote with the TV.
Emtronics is not listed and when I select other brands it comes up a sorry you will have to use your TV Remote.
Also Tried Vestel but had no luck.
Is there a code I can use?
Message posted on 20 Jan 2024 03:31 AM
Please tell me which one works. I am in the same boat
Message posted on 03 Feb 2024 01:53 PM
I had the same problem with EMtronics tv, just say its a JVC tv & it gave me 25 code attempts & got to number 24 attempt nearly giving no hope it would work & then bang the volume changed!! Happy days 😉👍
