Discussion topic: Sky remote code for EMtronics TV
This message was authored by: Ronnie21
Please can you advise when the remote control codes will be available for my new EMtronics TV? I am fed up with having to use 2 remotes, and not being able to use the voice control 😞
Re: Sky remote code for EMtronics TV
@Ronnie21 have you tried the using the codes for the vestel brand as they make a lot of TV's under different names
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @Ronnie21
Have you tried Other Brands in the remote setup @Ronnie21
Avatar for Ronnie21
thanks, that worked!!!
@Ronnie21 what one worked the vestel or the other brands ?
This message was authored by: Alistair12
Just in a job now and JVC codes worked.
This message was authored by: Papasmurff
What code worked having same issue ??
This message was authored by: Jackowock
Does anyone know where I can find the codes for the Emtronic EM32HDRW?
I've tried all the Emtronics models and the other brands codes.
many thanks
many thanks
@Jackowock have you tried the Vestel codes
Yes I have, but thanks for the suggestion.
This message was authored by: Danzigg1979
Hi, just purchased and set up a Emtronics EM40ROK TV with my Sky Mini Hub.
Tried to pair my Sky Q remote with the TV.
Emtronics is not listed and when I select other brands it comes up a sorry you will have to use your TV Remote.
Also Tried Vestel but had no luck.
Is there a code I can use?
This message was authored by: perfectbub
Please tell me which one works. I am in the same boat
This message was authored by: Shankly59
I had the same problem with EMtronics tv, just say its a JVC tv & it gave me 25 code attempts & got to number 24 attempt nearly giving no hope it would work & then bang the volume changed!! Happy days 😉👍
