Discussion topic: Sky q
Message posted on 28 Sep 2026 02:59 PM
Sky q
I want to move back to sky Q as I am not happy with sky glass picture quality rubbish . So what do I need to do
Message posted on 28 Sep 2026 03:01 PM
Re: Sky q
@roger+wetherick You'll need to call Sky however unless you're still in the cool off period you won't be able to return the Glass TV.
These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🔶📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
🔶online help via this link
https://www.sky.com/help
🔶 Sky Assistant should also be available via
🔶Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required.
Message posted on 28 Sep 2026 05:31 PM - last edited: 28 Sep 2026 05:32 PM
Re: Sky q
As @GD1 indicates, you've purchased the Glass television set and will typically be repaying the unsecured personal loan used to do so.
Sky will expect those payments to continue, (or the balance paid as a lump sum) even if you revert the content subscription to Q
Message posted on 28 Sep 2026 05:53 PM
Re: Sky q
Thanks I own the tv . Is the screen Bly way to change is to phone ?
Message posted on 28 Sep 2026 06:32 PM
Re: Sky q
@roger+wetherick wrote:Thanks I own the tv . Is the screen Bly way to change is to phone ?
You do need to call to get Sky Q either as a new customer or an existing one. Presuming you have a Sky subscription (which is beyond minimum term) on the Glass TV make sure they know you're wanting to switch from that to Q.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
