1750
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky q switches off - 15/05
Locked
This message was authored by: Ky25
Tv keeps turning off and going into standby
Tv keeps going into stand by while watching tv
This message was authored by: GreenP1
Problems with box not activating
The sky box does not activate at times and recently has started to cut out in the middle of a programme we are watching  and won't come back on
This message was authored by: KyanaCourtney
Tv not working
The sky Q box and the sky Q mini box aren't working at all. I have the right HDMI.
my tv is saying "no signal" and the box has a green light and the blue Q is flashing and the remote works fine.
This message was authored by: Smokie+19
Re: Sky q freezing on recorded programmes
Mind did this last night turn the box of 4 times still the same I went to bed and unplugged the box. When I turned It on this morning it's sorted the issue. Been ok for 4 hours with know problems at this time of posting. Don't know if it was turning it off all night or have sky sort it out in this area in South Wales
Re: Tv not working
Have you tried the recommended fix that Sky have mentioned for this problem;
Switch off your Sky Q box at the power socket for 30 seconds and back on again
Make sure you do the above on  your main box first and once up then do the same for your mini box or boxes.
This message was authored by: professor1999
Re: Sky q switches off - 15/05
I agree.  My sky q software version was up to date but i forced a refresh anyway - prese standby button on box as switch mains power back on.  It took 10-15 mins to complete.  By that time i had had enough - thanks SKY for ruining my evening- so did not test until this morning.  Seems ok now 🤞
This message was authored by: SusanBrenda
Re: My SkyQ box keeps turning off since last night including the mini boxes
Last night, 15th May, my sky Q went off three times, I rebooted  it each time andvit worked but went off again.
I understand it was acworldcwide thing, but have no other info.
It  seems okbtoday.
This message was authored by: Jaypers
This message was authored by: hitbox47
I unplugged my box overnight ( if you're reading this- try unplugging it for 1 hour )- it booted up in full reset mode (without losing recordings).
How can you tell it did a full reset? - It changes TV Resolution - when it 1ts booted, it was 720p, after one minute of loading it then switched to my TV resolution of 4k.
Since doing this from 7AM this morning, shutting it down after 30 minutes usage then coming back 2 hours later to fire it back up and all running fine.
My TV remote has worked perfectly (has issues last night), Recordings are playing perfectly, slight stutter going into the lower part of the recordings library but works, No crashes/Lock ups during recording playback (mutilple times last night), no lockups during live TV, Software version is Q300.000.06.00L (5yzv4ns).
If you are still having problems, my suggestion would be to leave it plugged out for at least 1 Hour, to give it time to do a full Reset- switching off and on again doesn't seem to be reseting settings enough for it to actually update itself or clear the issues.
Hope this helps anyone
This message was authored by: AndrueCope
@Lisa88 wrote:
I've just manually did a Software Update
Box has now completed the update, I've placed it into Standby mode and it's currently finishing up
From what I can see, it's sorted the issue
Now on version: Q300.000.06.00L (5yzv4ns)
Interesting. Mine's on Q310.000.13.00L (60neph0) and has been fine all morning.
This message was authored by: GC31
What compensation/refund is being offered by sky for all the inconvenience?
All
As previously suggested Sky are recommending a reboot of the boxes. If you're still having an issue with a mini box make sure you reboot the main box first.
So try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
This message was authored by: jonathanfrancis
Our Sky Q box (NE Hampshire) shut down twice last night 15.05 when watching a recorded programme, first time did a power cycle but gave up when did not fix the second time. Watched terrestrial instead so no issue with the TV.
As hitbox 47 did, I also left the box switched off overnight and powered up again this morning 16.05. All seems normal for the moment, have set box to standby and restarted again several times with normal behaviour so far.
A little early to be asking that.  It will take days (possibly many days) for any public announcement.
This message was authored by: Kacey12
My Sky Q still not working since yesterday evening have tried several times to reboot but cuts off after 10min. Sky this is unacceptable!!
Locked
Answered - Go to Answer
