Discussion topic: Sky q switches off - 15/05
Message posted on 16 May 2025 08:28 AM
Ive done everything possible and i cant contact you. Since approaching 9.20pm my sky Q box domy box
As perpétré wodely my sky Q box does lot work.
1. Have you been hacked and is there anything I should do (I can't change my network password as you've cut me off)
2. When will you advise paying customers
3. what is your compensation plan?
4. When will service be restored
Re: Sky q switches off - 15/05
I had the same problem of having to restart my Sky q box 5 times during the darts last night. I was watching it on playback.
Why do Sky not recognise these issues when so many users are reporting them?
Going to check later if this is still an issue.
Re: No signal
Mine is the same happened 3 times last night
Malfunctioning box
My sky a box keeps turning off l keep restarting it but its still turning off after about 5 minutes, any ideas? Thanks
Sky keeps craahing & having to unplug& reset
Last night 4 times my Q box crashed
While watching it.I had to unplug it & put back on which helped but kept doing it.It isn't 1st tone either last couple months its happened few times.
Message posted on 16 May 2025 08:29 AM
Crashing box
Anyone else experienced Sky box locking out, showing green power on light but not recting to controller? Only solution was to re-boot, but then it would crash again 15 minutes later. Only seemed to happen while watching recorded programmes.
Sky Q not working
Box just suddystopped working but the green light stayed on. This happened a number of times until it went no signal.
Have tried all things but still nothing.
Message posted on 16 May 2025 08:30 AM
Still not working or responding only option seemed to be ordering a new box
My Sky Q box not working, light is orange
Sky Q box kept switching off when watching TV. Switched everything off at the plug, started working OK, then started switching off again. Now the box won't switch on, light is orange. TV showing 'No Signal'
Re: Can’t use sky since last night. No satellite signal on screen but no reason why this should happ
Me too - still nothing this morning. New FFBB installed 3 weeks ago! Help
Message posted on 16 May 2025 08:31 AM
Sky Q box turning off internet
My sky q box keeps turning the tv off intermittently
Not working still
Since last night I have no sky access.
1. What is the problem
2. when will it be resolved
3 what is your compensation plan
Re: Sky Q box freezing
mine done the same when watching bbci player
Message posted on 16 May 2025 08:32 AM
Re: Sky switched off at 1030pm last night and still not working
Sky Q box keeps shutting down
From the number of (now locked) discussions, there is obviously a major problem with Sky Q, yet the technical help lines are not taking calls (due to 'technical issues'), and Sky is not issuing any information whatsoever.
There is obviously a problem affecting the whole of Sky Q, with boxes turning off and becoming unresponsive after 30 minutes or so. When can we expect a response from Sky?
