Discussion topic: Sky q remote
This message was authored by: Shauni93-
Sky q remote
Broken buttons on sky q remote, some work other don't. Replaced batteries but no way of using certain parts of it to watch TV.
Re: Sky q remote
@Shauni93-
If you follow this link it should send you to a form to request a replacement (I’m not sure if this is available to customers in the Republic of Ireland).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
In the meantime if you have an android or Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
▪️I AM NOT A SKY EMPLOYEE ▪️
This message was authored by: Gstevens83
Re: Sky q remote
I need a new remote.  Mine has broken
Re: Sky q remote
If only the way to do this was posted on the very thread you posted on... 🙄
