Discussion topic: Sky q remote setup unsuccessfull
This message was authored by martinhb This message was authored by: martinhb
Hi. Old sky q remote select button has stopped working so I have bought a new one. I unpaired the old one using 7 & 9 together. On the new on I selected 1 & 3 together and all I get is a setup unsuccessful message rather than a selection of tv brands to search through.
I have reset the sky q box.
I have used 7 & 9 on the new remote before trying the 1 & 3 buttons together.
I am pointing it directly at the sky q box from about a meter away.
At my wits end with it. It will control the sky q box but not the tv. Old remote did control the tv so not a compatibility issue.
Re: Sky q remote setup unsuccessfull
Hi @martinhb
Just a couple of points.
No need to unpair old remotes when replacing them with new ones.   Pairing a new remote automatically replaces the previous one.
Sometimes there are instances where pairing is unsuccessful and I have experienced this on occasions in the past.
All you can do is keep trying.  Assume you are using new batteries.
martinhb
Brand new batteries tested with a multimeter. Tried pairing for over an hour and still getting no where.
Hi @martinhb
Try a Reset Settings in the Q box hidden menu. This may help and does require re pairing after the reset. This may reinstate the pairing ability
martinhb
Already tried. Didn't work.
All you can do is keep trying occasionally @martinhb .
Also try pairing in Home - Settings - Setup - Remote control.
This message was authored by Chodley This message was authored by: Chodley
Don't you have to hold 7&9 on the new remote first before doing 1&3?
This message was authored by JamboJJ This message was authored by: JamboJJ
Hi, I'm having the same issue and have tried all of the above. Was this resolved another way? Thanks
martinhb
Unfortunately not. I'm still going crazy and having to use multiple remotes.
