28 Mar 2024 05:21 PM
I rejoined sky and nothing seems to be working except l can get tv using the sky go app on my iPad.
lesleyimrie
28 Mar 2024 06:02 PM
lesleyimrie
Hi @Lesleyimrie
Not working doesn't give us any clues.
Is the Q box on with green LED on the right hand side?
Is there any message on the TV set?
Have you tried rebooting the Q box?
28 Mar 2024 06:32 PM
I have tried everything you have mentioned the remote and lights are working still says a technical fault.
lesleyimrie
28 Mar 2024 06:35 PM
lesleyimrie
Technical fault helps @Lesleyimrie
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
28 Mar 2024 06:52 PM
I have done everything you have mentioned and the remote and lights are working fine but I still have no tv.
lesleyimrie
28 Mar 2024 07:07 PM
lesleyimrie
Have you tried everything in the link I posted @Lesleyimrie ??
29 Mar 2024 10:45 AM
I now can't get my sky box to turn green.
lesleyimrie
29 Mar 2024 10:47 AM
I can't get my sky box to turn green.
lesleyimrie
29 Mar 2024 03:01 PM - last edited: 29 Mar 2024 03:02 PM
lesleyimrie
Have you tried pressing the Amber led on the front of the box @Lesleyimrie ?
If it will not come on then work through the following link and it will lead to a conclusion
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Don’t forget to keep your viewing card from the failed box if you order a replacement. Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
