Discussion topic: Sky q remote setup unsuccessfull
Message posted on 20 Feb 2024 07:35 PM
Hi. Old sky q remote select button has stopped working so I have bought a new one. I unpaired the old one using 7 & 9 together. On the new on I selected 1 & 3 together and all I get is a setup unsuccessful message rather than a selection of tv brands to search through.
I have reset the sky q box.
I have used 7 & 9 on the new remote before trying the 1 & 3 buttons together.
I am pointing it directly at the sky q box from about a meter away.
At my wits end with it. It will control the sky q box but not the tv. Old remote did control the tv so not a compatibility issue.
Message posted on 20 Feb 2024 07:41 PM
Re: Sky q remote setup unsuccessfull
Hi @martinhb
Just a couple of points.
No need to unpair old remotes when replacing them with new ones. Pairing a new remote automatically replaces the previous one.
Sometimes there are instances where pairing is unsuccessful and I have experienced this on occasions in the past.
All you can do is keep trying. Assume you are using new batteries.
Message posted on 20 Feb 2024 07:48 PM
Brand new batteries tested with a multimeter. Tried pairing for over an hour and still getting no where.
Message posted on 20 Feb 2024 07:56 PM
Hi @martinhb
Try a Reset Settings in the Q box hidden menu. This may help and does require re pairing after the reset. This may reinstate the pairing ability
Message posted on 20 Feb 2024 07:59 PM
Already tried. Didn't work.
Message posted on 20 Feb 2024 08:02 PM
Message posted on 20 Feb 2024 11:55 PM
Don't you have to hold 7&9 on the new remote first before doing 1&3?
Message posted on 29 Mar 2024 12:13 PM
Hi, I'm having the same issue and have tried all of the above. Was this resolved another way? Thanks
Message posted on 29 Mar 2024 02:54 PM
Unfortunately not. I'm still going crazy and having to use multiple remotes.
