This discussion topic has been answered Discussion topic: Sky q remote not working
Message posted on 05 Dec 2023 07:38 PM
Sky q remote not working. Changed batteries etc tried pressing 1 & 3 together (red light just flashes) all it does it turn tv off after long press of standby button. Oh for the android sky virtual remote 😁 Do i have a dodgy q remote ? 👍
Message posted on 05 Dec 2023 07:41 PM
Try a reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then try the re-pair as you have tried already :
press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
If needed see also
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
If needed see also
Message posted on 05 Dec 2023 07:53 PM
Re: Sky q remote not working
Had to switch off the q box at the mains to begin with but getting set up unsuccessful error
Message posted on 05 Dec 2023 07:56 PM
Seems to be working now🤞
Message posted on 28 Oct 2024 07:45 PM
I've tried all of this and still not working
Message posted on 28 Oct 2024 08:07 PM - last edited: 28 Oct 2024 08:09 PM
@Degan
Your duplicate post has been removed.
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (there is the possibility this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
In the meantime it may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
