Discussion topic: Sky q remote disconnected
This message was authored by Ebonymadi2908 This message was authored by: Ebonymadi2908
My remote has disconnected and I can't for the life of me reconnect it I've held in both 1&3 and 7&9 can anyone help please
Re: Sky q remote disconnected
hi @Ebonymadi2908
Its no good just randomly pressing the buttons.   It needs to be done in the correct sequence.
First reboot your Q box.
Have you tried rebooting your Q box?
Then
