Discussion topic: Sky Q and fibre
This message was authored by: IanB25
Sky Q and fibre
Hi,
I have Sky Q TV and am getting full fibre, but just realised that this means that the Q in my garden room may no longer work, as it's too far from the Sky Q main box. Currently I have a lan cable running from the router to the garden room, where it plugs into a booster. This connects to the mini box and gives me TV and broadband. Presumably this set up won't work if I have fibre?
This message was authored by: JibbaJoy
Re: Sky Q and fibre
@IanB25 wrote:
Hi,
Hi @IanB25  No, it will still work with full fibre if everything else stay where it is - ie modem/router doesn't move the new router connects to the full fibre termination box (now the modem) via a lan cable so hopefully you'll be able to place the new router where the old one currently sits
SkyQ [H/W: 32B106] + 3 mini
Samsung 55" Neo QLED UHD TV
Swish Fibre 150 Symetrical
Linksys MX5400 Mesh network
This message was authored by: profile
Re: Sky Q and fibre
Not sure I understand your problem?
if you currently have Sky broadband and a Sky Router, then after Fibre (sky/openreach?) is supplied to your property, all you need to do is reconnect the router to the fibre terminations ethernet socket and everything is as before?
I think if you don't have sky broadband,  then when reconnecting the sky router, the miniboxes will no longer provide wireless hotspots (access points) without re-enabling them for none-sky fibre(in settings/network/advanced/hotspots) , or you can still use an unmanaged switch to connect mini's and tv etc using ethernet cables.
