Discussion topic: Sky q not working
Message posted on 17 Aug 2024 10:41 AM
Sky q not working
We have a new LG OLED Tv and when we use our sky q box the picture keeps turning on and off. The tv works fine when we play Netflix or prime video direct through the tv so there is something wrong with the sky q box. Prior to changing the tv the sky was working fine
Message posted on 17 Aug 2024 10:51 AM - last edited: 17 Aug 2024 10:53 AM
Re: Sky q not working
Hi @Dancb8 I would check that all the cables are seated properly and/or perhaps try a new high speed HDMI cable. What is the length of your HDMI cable that you are using now, is it the original supplied with the Sky Q box?
Message posted on 17 Aug 2024 11:30 AM
Hi
its the same cable that worked properly before. I will double check they are all connected correctly
Message posted on 17 Aug 2024 11:32 AM
@Dancb8 wrote:its the same cable that worked properly before.
Length etc. as asked above?
