Discussion topic: Sky box. Mini
Message posted on 17 Aug 2024 06:53 AM
Sky box. Mini
My sky minibox is constantly red no matter whether we reset it is press controls
Message posted on 17 Aug 2024 11:34 AM
Re: Sky box. Mini
Hi @Senna
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the mini box on with green led try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Failing this
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
