Discussion topic: Skyq not working
Message posted on 17 Aug 2024 10:11 AM
Skyq not working
Tv saying sky q not connected only on one tv
Message posted on 17 Aug 2024 11:30 AM
Re: Skyq not working
Hi @Dawn241
Assume the issues is with a mini box.
Reboot the mini as above.
