Discussion topic: Sky q minis keep disconnecting
Message posted on 14 Jul 2025 10:02 AM
For the last 2 months our sky q minis boxes keep disconnecting. As soon as one box connects, the others loose connection. I am so fed up with this I am considering cancelling sky. It is impossible to talk to anyone on the phone and all the sky web help does is keep sending me new mini boxes!! The problem persists with the new boxes, so surely the problem must be the sky router or the sky main box? Anyone know how I can connect to a human at sky?
Message posted on 14 Jul 2025 12:45 PM
							Re: Sky q minis keep disconnecting
Hi @8803rick Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, do the same with any Mini boxes?
Message posted on 16 Jul 2025 10:57 AM
Hi, thanks for this. Temporarily solves the problem, but as soon as I reactivate the next mini box, the one i have just reactivated has no connectivity. I just need to talk to someone at sky. Anyone know how to get to a human?
Message posted on 19 Jul 2025 05:07 PM
@8803rick You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number.
If you are in ROI please change the flag at the bottom right to the ROI flag
If you do not freply and say nothing when asked what you are calling about you should get through to a human
