18
This discussion topic has been answered Discussion topic: Sky q mini box not working
This message was authored by: Markakyhome
Tv shows no signal I have rebooted the mini box several times and nothing gets this working !
This message was authored by: KevNewMedia Answer
Re: Sky q mini box not working
Posted by a Sky employee
Hi Everyone
Thank you for coming to the Community to report the problems that you've experienced.
We sincerely apologise for any inconvenience this has caused and can confirm that the original problem has now been resolved.
As many people have found, your main Sky Q box should be powered off at the mains for 30 seconds first, followed by your mini boxes.  If you continue to have problems, you can also find from the Community or our help article here.
I'm going to mark this post as the answer, so that everyone has the most up-to-date information.
Kev
Community Manager
Hi @Markakyhome
Reboot the mini as above.
Avatar for Markakyhome
Guess what I tried all that and no I don't need a booster since the mini box is the unit closest to the router
This message was authored by: Jackfloyd
Still won't work
This message was authored by: Lollierose25
Mine won't work either. The mini in another oom works fine and the main q box works as well so god knows what's going on it was working yesterday
This message was authored by: PAULBARRY31
I have two mini boxes and they have both gone down at the same time in different rooms.
Bothboxes are locked up and the remote doesn't move anything
Just says
Accessibility on Sky Q
New today, you can magnify your screen and some other extras.  The screen on both boxes is the same and it's frozen.  Tried reset button, new batteries pulled cables out nothing works.
Go to settings > Accessibility
Just says
@PAULBARRY31 try the following...
Unpair their Sky Q remote from the box by holding 4&6
Wait for the remote to flash you should then be able to dismiss the information screen by clicking on Skip & set up later
Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control your TV.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: balmpral44
my Sky mineQ box not working
thanks so much very helpful
This message was authored by: LBskyguy
I'd add to below .If you are NOT a Sky broadband user ...still select sky broadband router when asked to connect mini box to network .I am on EE and was ignoring SKy router and selecting alternative....and trying to connect mini box to EE ...you can do it but it kicks off the main Q box.
Select Sky router...and hit wps on Q box.Sky engineer confirmed that instruction to select an alternative router is wrong and caused more issues than anything else.Sky need to change self help instructions and better train phone techs.
Another tip ...make sure eco setting on both boxes are " NONE"...SETTINGS/ SETUP/PREFERENCES/NONE/CONFIRM
This message was authored by: Dawniepuss
Hi one of my mini boxes is still not working
This message was authored by: Thedocsays
Markakyhome 's advice to reboot main sky Q box then the mini Q box worked for me !  - saved waiting a week for engineer 👍
This message was authored by: Cullyboy9
Sky mini box not working
Sky Q mini box has stopped working, all I have is a blue screen with Accessibility on Sky Q, with two options, Settings or skip and set up later.
I've tried all of the suggested resets, but it keeps coming back to this screen.  Remote will not let me select anything.
Has anyone else had this?
Re: Sky mini box not working
hi @Cullyboy9
This message seems to have caused a bit of a quirk so try this:
Press & hold 4 & 6 on the remote to set to Infrared only (so must have line of sight of the box)
Hopefully you can then dismiss the message
Then try re-pairing in bluetooth mode with the box by pressing & holding 1 & 3 together
If this does not work try a full remote reset by pressing & holdng 7 & 9 until the red led above the SKY logo button flashes 4 times
Then try the 1&3 to re-pair & pair with the TV
@Cullyboy9
Sky have previously suggested the following...
  • Unpair their Sky Q remote from the box by holding 4&6
  • Wait for the remote to flash
  • Then dismiss the information screen "Skip & set up later"
  • Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV.
Answered - Go to Answer
