Discussion topic: Sky q mini box not working
This message was authored by: Markakyhome
Tv shows no signal I have rebooted the mini box several times and nothing gets this working !
Re: Sky q mini box not working
Hi @Markakyhome
Reboot the mini as above.
Avatar for Markakyhome
Guess what I tried all that and no I don't need a booster since the mini box is the unit closest to the router
This message was authored by: Jackfloyd
Still won't work
This message was authored by: Lollierose25
Mine won't work either. The mini in another oom works fine and the main q box works as well so god knows what's going on it was working yesterday
This message was authored by: PAULBARRY31
I have two mini boxes and they have both gone down at the same time in different rooms.
Bothboxes are locked up and the remote doesn't move anything
Just says
Accessibility on Sky Q
New today, you can magnify your screen and some other extras.  The screen on both boxes is the same and it's frozen.  Tried reset button, new batteries pulled cables out nothing works.
Go to settings > Accessibility
Just says
@PAULBARRY31 try the following...
Unpair their Sky Q remote from the box by holding 4&6
Wait for the remote to flash you should then be able to dismiss the information screen by clicking on Skip & set up later
Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control your TV.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: balmpral44
my Sky mineQ box not working
thanks so much very helpful
This message was authored by: LBskyguy
I'd add to below .If you are NOT a Sky broadband user ...still select sky broadband router when asked to connect mini box to network .I am on EE and was ignoring SKy router and selecting alternative....and trying to connect mini box to EE ...you can do it but it kicks off the main Q box.
Select Sky router...and hit wps on Q box.Sky engineer confirmed that instruction to select an alternative router is wrong and caused more issues than anything else.Sky need to change self help instructions and better train phone techs.
Another tip ...make sure eco setting on both boxes are " NONE"...SETTINGS/ SETUP/PREFERENCES/NONE/CONFIRM
