Discussion topic: Sky q box
This message was authored by: verstan
Sky q box
For 2 days now skyq box not working. Keep having to unplug and plug again for it to work . What's the problem. Pay enough to sky but can't get an answer to the cause of it.
Re: Sky q box
I have moved your thread to a more appropriate forum
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
Re: Sky q box
Hi @verstan
