Discussion topic: Sky q no satellite connection
This message was authored by Walker32 This message was authored by: Walker32
Hi,
The Sky q box has displayed this message for the last few days. It is effecting all channels.  Apprently when the service check is done, everything is working fine but obviously it isn't.  It has been reset, all wires checked. At a bit of a loss right now. Any ideas that might help?
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: Sky q no satellite connection
@Walker32
If a message displays “no satellite signal” it relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
