Discussion topic: Sky q box
This message was authored by: StuartC1
Sky q box
My sky q box is on standby and won't switch on
Re: Sky q box
Hi @StuartC1
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Avatar for StuartC1
Re: Sky q box
Thanks i have got through to sky on phone and we have done exactly what you suggested and the sky box is now working
