18 Apr 2024 12:39 PM
My sky q box won't download anything. I've checked I've got the latest updates & I have. I've changed my preferences to SD, as I saw someone suggest that, but still nothing. Please help!
18 Apr 2024 12:51 PM - last edited: 18 Apr 2024 12:56 PM
Hi @Dramaqueen2
Can you give an example of exactly what you are trying to Download?
Edit
And also what message do you receive when you try?
18 Apr 2024 01:19 PM
Hiya, thanks for replying. If I try to download from catch up, on demand, sky cinema, anything at all, a message comes up saying 'due to a technical issue, your download couldn't be completed. Please try again later'
18 Apr 2024 01:25 PM
Hi @Dramaqueen2
Assume you have already tried rebooting your Q box?
18 Apr 2024 03:09 PM
@oldfella I haven't rebooted, I don't know how!
18 Apr 2024 04:26 PM
Hi @Dramaqueen2
@Dramaqueen2 rebooting your main Q box ie
23 Jan 2025 08:22 PM
I had the same problem and it went away when I changed the DNS address. Definitely worth trying if you have no issues with other services like Apple or Netflix.
From what I understand this is quite a common problem with Sky and non-Sky Routers.
You need to go into the settings page and select Network Connection then Network Setup. On the next page go down to Advance Settings and then Edit. Go down to DNS Server and enter 8.8.8.8, then press confirm. Might need to restart the box.
13 Feb 2025 09:38 AM
I've had all the same issues since once November
wont down load
after 8 engineer visits broad band and tv
3 new hubs
2 new sky boxes
new ip address and viewing card all leads too.
very conversations with TAPS changing all server settings and still nothing.
latest guy after two hrs was lost for words with working with sky for over 20 years !!!!
any update or feedback would be great
