Discussion topic: Sky q box will not turn on,
Message posted on 27 Oct 2024 07:25 PM
Sky q box will not turn on 1 green light only tried turning off at mains and disconnected from tv for at least 3-4 mins rebooted q light flashes but after on 1 green light tried pressing 7&9 green light flashes 4 times then pressed 1&3 green light flashes but that's all that happens???
Message posted on 27 Oct 2024 07:30 PM
Re: Sky q box will not turn on,
Hi @Paul397
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Message posted on 27 Oct 2024 07:36 PM
I've pressed the button to the right of the amber?? Light this then flashes green again I've followed remote no's etc but nothing happening light then goes out thanks for your help though
Message posted on 27 Oct 2024 07:41 PM
Don't know what or how but after what must be 2 hours trying to sort,walk away with tv and sky box showing green light when got back sky menu shown on screen ureaka thanks for input
