Discussion topic: Constant loss of internet connection on skyq
Message posted on 25 Oct 2024 09:53 PM
I hope someone can help.I have tried all the usual suggestions of turning off box and then router and it works for a while and then goes down again.I have bt internet
can anyone help please
Message posted on 26 Oct 2024 12:26 AM
Re: Constant loss of internet connection on skyq
Try splitting the 5 and 2.4GHz wifi networks on your router to different SSID names. The Q can only use 2.4GHz with non-Sky routers and this has helped some people.
other than that, I gave up on Q's wifi with BT (and subsequently a fibre indie)
Message posted on 26 Oct 2024 11:32 AM
Thank you for responding,I have found out that the Wi-Fi is already split so I will keep looking for solutions
Message posted on 26 Oct 2024 03:30 PM
BT routers used to have this "smart wifi" thing which has a rep for causing problems with Q. I never used one (homehub 6 or something introduced it but I was already using my own router and wifi mesh by then)
Message posted on 26 Oct 2024 06:14 PM
Thank you for taking the trouble to reply but I wouldn't know how to make the changes that you suggest
Message posted on 26 Oct 2024 09:51 PM
It was a very obvious option back in the day so if it's not there on the router config I suspect BT no longer do the same thing.
Message posted on 26 Oct 2024 10:16 PM
Thank you again for taking the trouble to post
Message posted on 26 Oct 2024 10:24 PM
Honestly I would try powerlines, ethernet connections to those and disabling wifi.
I gave up on wifi after fighting this battle for years.
Message posted on 27 Oct 2024 08:39 PM
