Discussion topic: Can’t get channels using remote
Message posted on 27 Oct 2024 05:58 PM
Remote won't change channels. We just get a message saying Accesibilty settings???? Won't let us remove message.
Message posted on 27 Oct 2024 06:03 PM
Re: Can’t get channels using remote
Sky have suggested the following...
- Unpair their Sky Q remote from the box by holding 4&6
- Wait for the remote to flash
- Then dismiss the information screen "Skip & set up later"
- Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV.
Message posted on 27 Oct 2024 06:17 PM
Note that where an onscreen message is being generated by a smart television set operating system rather than a Sky box, it typically requires use of the television remote control rather than the Sky handset to acknowledge or dismiss it.
Message posted on 27 Oct 2024 07:11 PM
We tried this but still didn't clear. Thanks for trying to help though 🙏
