Discussion topic: Sky q apps
Message posted on 22 Aug 2024 06:24 PM
Sky q apps
Hi
i I have sky q and the apps are not working including Netflix. Is there a system issue?
Message posted on 22 Aug 2024 06:47 PM
Re: Sky q apps
@Mitch17 wrote:
Hi
@Mitch17 Have you tried rebooting your main Q box ie
if that doesn't help
then
you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
