Discussion topic: Handset not operating the Sky Box
Message posted on 22 Aug 2024 02:29 PM
The Handset is not communicating with the sky box, can't open the menu after start up.
Iv'e tried the advice on line pressing 1&3 and also 7&9 but although the handset lights up it dosen't operate the Sky Box.
Message posted on 22 Aug 2024 02:34 PM
Re: Handset not operating the Sky Box
Hi @Crackers3 After holding down 7 & 9 until you see 4 flashes. Are you pointing the remote towards the box (direct line of sight) does it work. Have you power (unplugged) rebooted the box. Leave it off for at least 30 seconds to ensure it is not "frozen".
Message posted on 22 Aug 2024 02:38 PM
Hi @Crackers3 If you follow the help pages, it will lead you to a request free replacement form if required.
Message posted on 22 Aug 2024 02:39 PM
Hi MQ thanks for your reply.
Ive turned of the box and rebooted many times but haven't taken the plug out, so i'll try this now.
Message posted on 22 Aug 2024 02:49 PM
Hi MQ Thanks for that!
The handset started up the programs, but only works the other oprations if I place the handset very close to the box.
Message posted on 22 Aug 2024 02:50 PM
@Crackers3 wrote:The handset started up the programs, but only works the other oprations if I place the handset very close to the box.
Tried new batteries?
Message posted on 22 Aug 2024 02:56 PM
Yes, but not sure how good they are so will pick up some new ones.
Message posted on 22 Aug 2024 05:30 PM
Thanks, picked up some Duracell batteries and it seemed to do the trick, won't pick those cheapo ones again.
Message posted on 22 Aug 2024 06:00 PM
Hi @Crackers3 Yes, check batteries was the first item on that link I gave you 😀
