Discussion topic: Sky not working
This message was authored by: Scooternbeans
Sky not working
Showing ! No Signal (is it on ?)
Re: Sky not working
@Scooternbeans wrote:
Is it on ?
The satellites are still up there,
ensure you've power cycled the box and the TV is set to the right input.
Re: Sky not working
@Scooternbeans Just in case you'e not aware a satellite signal covers the whole of the UK, if it was "off" there would quite literally be 1000's of posts about it.
It sounds like the issue is at your end.  Have you rebooted your box?
Re: Sky not working
Hi @Scooternbeans
No Signal is normally a TV message suggesting that the TV is not switched to the correct HDMI input.
If it was a Q box message it would be No satellite signal.
Is the Q box on with green led ?
