Discussion topic: Sky not turning on
Message posted on 12 Feb 2025 03:57 PM
Sky not turning on
Message posted on 12 Feb 2025 04:34 PM
Re: Sky not turning on
@LucyWillicombe7 wrote:
It's happened a few times now. The sky won't turn on unless I switch it off by the plug and reset it?
@LucyWillicombe7 You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 13 Feb 2025 07:52 AM
Thank you. Il give this a try once I'm back home.
