Discussion topic: Sky mini stick on red light
This message was authored by: BazzaN
Hi. I have 2 mini boxes that have worked fine until now. One now just had the red light and won't go out of standby. I have tried putting down with reset and powering back up with reset still pressed lots of times, but no better. If I unplug without reset the ref light goes on for about 3 servings when powered break up then no light. With reset red just stays on. What other options do I have of test didn't work. Thanks in advance.
Re: Sky mini stick on red light
Hi @BazzaN
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Avatar for BazzaN
Thanks for the quick response. This is a mini box and I only have the red stand by light on. I have reset multiple times and the remote appears to be working.
Hi @BazzaN
Yes I know it is a mini @BazzaN
The Red/Amber standby light is also a power switch.
Just asking if you have tried this to switch it on
Avatar for BazzaN
Hi yes tried pressing this and also during a reset and power down / up.
Hi @BazzaN
Just to be sure,  the button you press and hold during a power up(ie the mini recovery procedure) is the small reset button on the back of the box (not the power switch on the front)
Avatar for BazzaN
Hi - yes the I was using the small reset button at the back.
