Discussion topic: Sky mini connection issue
Message posted on 05 Nov 2023 09:41 PM
My sky mini box has moved further away from the sky q box and now won’t connect. Can I use anything to help the signal between the two boxes?
Message posted on 05 Nov 2023 09:44 PM - last edited: 05 Nov 2023 09:46 PM
Re: Sky mini connection issue
Hi @Pricey791
Reboot the mini as above.
Sky should supply one free of charge to aid Sky Q connectivity.
