Discussion topic: Help with sky q minis and no internet
Message posted on 05 Nov 2023 09:28 PM
Basically we have a maim box plus 4 minis and now have no internet for 2 weeks. We have limited functions on main box which will be fine but none of the minis are working at all. Can anyone help please?
Message posted on 05 Nov 2023 09:54 PM - last edited: 05 Nov 2023 09:55 PM
Re: Help with sky q minis and no internet
According to the following link your minis should work with limited functions.
https://www.sky.com/help/articles/features-available-without-broadband
Try the following on the nearest mini
Reboot the mini as above.
