Discussion topic: Sky mini boxes
Message posted on 02 Sep 2023 06:00 PM
Sky mini boxes
Sky mini boxers not connecting
Message posted on 02 Sep 2023 06:08 PM
Re: Sky mini boxes
@Marang wrote:
Sky mini box will not connect
'Hi @Marang
Reboot the minis as above.
If the mini still does not connect try a Network Reset on the mini nearest to the main Q box
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
For your second mini carry out a network reset as above and you can use WPS on the first mini if nearer than the main Q box (or Q router if on Sky Broadband)
Message posted on 03 Sep 2023 11:11 AM
Re: Sky mini boxes
Had sky for nearly 18 months and no issues whatsoever. However, yesterday I started getting issues as well. Sky box randomly losing internet but mainly the sky mini boxes not connecting.
did the reconnection to sky box using WPS and was fine for a bit then the sky mini dropped again.
any idea what's happened as seems a few people are having this issue all of a sudden all around the same time. Can't see there has been any updates?
Message posted on 03 Sep 2023 11:19 AM
Re: Sky mini boxes
Have now followed oldfellas instructions above and just switched off power to both boxes and turned back on. Now done a network reset again on the sky mini and it's back on again now. Fingers crossed it stays on this time.
also, noticed when I did the network reset last time, when I went into network it showed the network as Sky***** and not my router. This time when I've done it, it's now correctly showing my router again. Wonder why it was showing as sky (which I assume was the main sky q box)?
