Discussion topic: Recordings disappeared. Turned on TV this evening, nothing in recordings. Have rebooted tv box and .
This message was authored by: And27
Can anyone help?
Re: Recordings disappeared. Turned on TV this evening, nothing in recordings. Have rebooted tv box a
@And27 wrote:
Can anyone help?
@And27 You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
