Discussion topic: Sky mini box
This message was authored by: Jane122
Sky mini box
Mini box isn't working, saying connectivity issues, no satellite signal, I've followed the reset instructions numerous times.
Re: Sky mini box
Hi @Jane122
Don't know what reset instructions you have followed.
Reboot the mini as above.
