Discussion topic: Sky mini box
This message was authored by: Marnie66
Sky mini box
I have a satellite signal for my main box but I have nothing on my sky mini box although everything says the 2 are connected?
Re: Sky mini box
Hi @Marnie66
I have deleted your last post as it is not necessary to start multiple threads with the same issues.
Reboot the mini as above.
Re: Sky mini box
@Marnie66
I've also deleted another thread you've started on the same issue. It's not needed and causes confusion and duplication of replies. You need to follow the advice from @oldfella
