06 Sep 2024 12:44 PM
Mini box isn't working, saying connectivity issues, no satellite signal, I've followed the reset instructions numerous times.
06 Sep 2024 01:24 PM
Hi @Jane122
Don't know what reset instructions you have followed.
Reboot the mini as above.
