Discussion topic: Sky mini box
This message was authored by: Roll+on+school
Sky mini box
I have done all the resting and now i can't get my mini box to come its saying there's no viewing card in
i can't confirm to order a new mini box because it's telling me to use my old card.
Re: Sky mini box
@Roll+on+school
Mini boxes don't have viewing cards. Only the main Sky Q box needs a viewing card (and has a slot for it).
HAPPY NEW YEAR
Avatar for Roll+on+school
Re: Sky mini box
Thanks for that I didn't know.
I can't get it on for anything I've done everything it's told me online I've even changed batteries in the rent and still nothing happening
Re: Need to order a sky q mini box replacement
I can't get in touch with sky
Hi @Roll+on+school
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue.
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
