4
This discussion topic has been answered Discussion topic: Sky multiscreen
This message was authored by: Carl1401
Sky multiscreen
Can you watch two different programs using sky multiscreen?
Re: Sky multiscreen
@Carl1401
Yes. You can watch different live TV or different recordings on a mini box and main box. (UHD doesn't work on a mini box).
Re: Sky multiscreen
@Carl1401
Avatar for Carl1401
Level 0 icon
Re: Sky multiscreen
Ok thank you.
So if I wanted to put it in my sons room, it would give him access to our full sky account??
Re: Sky multiscreen
@Carl1401
Yes. All recordings are stored on your main Sky Q box only.
In case you're not aware, you can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+. It’s worth mentioning that UHD content can’t be viewed on a mini box.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
Avatar for Carl1401
Level 0 icon
Re: Sky multiscreen
Thank you for all the information.
Very much appreciated
