4
This discussion topic has been answered Discussion topic: New skyQ box and Screen go's black for a few seconds
This message was authored by: Viking71
I've just had a replacement skyQ box and ever since the TV screen will turn back for a few seconds
Avatar for Viking71
This message was authored by: Viking71 Answer
Re: New skyQ box and Screen go's black for a few seconds
Problem is sorted now. The  new sky box was sending a ultra H D signal to my TV but my TV isn't an ultra TV so went to picture quality and adjusted to standard H D  and all sorted....
@Viking71
Is this on Sky sports channels?
Avatar for Viking71
No it's happening on all channels
Hi @Viking71
Avatar for Viking71
