This discussion topic has been answered Discussion topic: Sky mini box not responding to the remote control
Message posted on 25 Jun 2024 04:17 PM
Sky mini box will not respond to the remote control you can switch on manually but then nothing works just stuck on the menu
Message posted on 25 Jun 2024 08:13 PM
@Bailey183 wrote:
My mini box is not working at all it seem to be on stand by And nothing happens
@Bailey183 what happens when you press the stanby button on the mini box the standby button is where you see the amber light.
If it comes on then Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 25 Jun 2024 05:02 PM - last edited: 25 Jun 2024 05:02 PM
Re: Sky mini box not responding to the remote control
Hi @Dean1311
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Message posted on 25 Jun 2024 05:43 PM
Hi Oldfella. What a star you are all back up and running perfect enjoy your day.
Message posted on 25 Jun 2024 06:43 PM
