Discussion topic: Bbc1 hasnt been working for over 2 weeks. The picture is distorted
Message posted on 25 Jun 2024 07:52 PM
Hi bbc1 isn't working. The picture is distorted it's been like this for 2 weeks
Message posted on 25 Jun 2024 07:54 PM
Re: Bbc1 hasnt been working for over 2 weeks. The picture is distorted
Any error message on screen such as 'no satellite signal'?
Message posted on 25 Jun 2024 08:05 PM
No just a distorted picture
Message posted on 25 Jun 2024 08:09 PM
It does seound like the dish might be slightly out of alignment so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
If you are connected to a communal dish you’ll need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
